Hi everyone hope you can help - i am doing some decorating for a friend and this is the problem i am having - I have stripped the wallpaper as it looked as though patches of damp were causing the paper to peel away and discolour, i tested the walls with a damp meter and they were within acceptable limits to be on the safe side i thought i would use oil based gloss undercoat (leyland trade) I applied undercoat and within minutes yellow staining has shown through!
I then got some stain sealer (crown i think) this is way thicker and applied - once again it stained within minutes.
The stains are blotchy
The room is upstairs with two exterior walls - the house was built 1820s and has had the brickwork outside painted
Any help would be appreciated
