Hi all, first time on the site!
A couple of months ago we had an upstairs light bulb literally blow up, i traced this to a loose earth wire in the ceiling rose......
A week ago my upstairs lights didn't work. I checked the bulbs - ok, ceiling roses - connections ok, fuse on the consumer unit - wasn't blown.
The next morning I switched the lights on and everything worked fine.
The same thing happened a couple of days later so i took the fuse out of the consumer unit to be on the safe side.
As i can't get an electrician out for 3 WEEKS!!! locally, i wondered if anyone had had a similar problem / could explain it so i don't get stitched up when they come to do the work.
I think it might be a bad connection in the consumer unit because it's the last fuse on the board, farthest from the incoming supply.
Could it be linked to the earlier incident?
Any help would be appreciated!!
Best regards, Matt
Best regards, Matt
