I want to replace the light in my bathroom which is one of those single swivel ball spotlights and turns on with a pull down switch, to a metal 4 spotlight and metal dimmer switch.
There are 2 black wires and 1 red going into the spot light, both black to neutral , red to live, the pull down switch has one red going to the spot light , and the other end in the pull down switch i believe is connected to my lads rooms.
How and what would be the best way to connect these wires. when i remove both reds from the pull down switch , can i join it as one or do i still keep them separate from each other or use a junction box which i want to do, do i still keep both black neutral together ?
The new light has your standard live neutral and earth connections, how do I connect to the dimmer switch, which goes to l1, L2 and (~), earths not a problem , and i've already cut out the recess for wiring and the box on my landing, but this wiring is stumping me.
Any suggestions on how to go about it and wire it correctly would be a fantastic help , thanks
