After moving in and ripping up the carpets I discovered my 1930's built house has 14mm floorboards which are looking worse for wear, so I decided to replace them. However they seem to fit snugly between joist and wall and new flooring is at least 18mm thick. Do I; 1) Shave the ends of new floorboards to 14mm. 2) Chip away at the wall to create a bigger gap. 3) Lay the new floorboards on top of the old?
Any other advice or suggestions would be welcome.
