- Joined
- 2 Jul 2010
- Messages
- 237
- Reaction score
- 4
- Country
In the hope that there are some experienced "deep crack" fillers on the forum I would be grateful for some advice on the following.
I have a concrete window cill with a crack running along the length of the top face. In parts this crack is around 4" deep lessening in depth towards the ends. I have cleaned it up and raked it out ready for filling, however, I will not be able to press the filler right down to the bottom due to the narrow width and irregular shape of the crack.
I had thought of using some expanding foam to get right to the bottom then cut the foam back a bit at the top and apply the top level of filler (Toupret Masonry Filler). Alternatively, could I sprinkle in some dry quick setting premix powder to get to the bottom of the crack then let it harden off by absorbing moisture, then, follow this up with the top level of filler?
On reading the data sheet for the Toupret Masonry filler it states it should not be applied onto soft or friable backgrounds so I am unsure if I can use it on top of the expanding foam unless there is a foam version that sets hard?
Once filled, the cill will be painted with masonry paint.
Any advice most appreciated.
Rgds
Jack
Rgds
Jack
