Hi, I have a simple 1 way dimmer which I would like to use to replace my 1 way light switch. My lights do not exceed the maximum wattage of the dimmer. I would like some clarification on wiring.
The switch plate on the wall has 3 red wires entering it
1) wired to a connection on the plate marked 'cov'
2) & 3) the other 2 red wires are in the terminal marked L1 (there is an L2 but that is empty
The earth wire is connected to the back box.
The dimmer I purchased has 2 terminals, one marked L2 and the other a symbol like an x with an arrow head. the diagram that came with the dimmer stated - wire the mains supply to L2 and the 'lamp' to the symbol I described above.
light fitting has 3 bulbs each 60 watts. dimmer max is 250w
Some direction would be reassuring
Many thanks
Many thanks
