I was changing a socket faceplate on a socket on then upstairs circuit.
I switched off the relevant mcb that covers the upstairs circuit.
I disconnected all the wires from the faceplate and at that point I realized that the washing machine downstairs was quiet.....all the downstairs circuits are on a different mcb but same rcd. The rcd had tripped.
Is this normal or is there a fault with the wiring? I thought that maybe when i disconnected the earths at the socket the rcd may have picked this up. But I don't understand why this would have happened since i have switched off the mcb serving the upstairs ring.
Everything is back on now but i am curious to find out as to what might have happened.
Many thanks
Many thanks
