Sorry i can't find a model number. Its a Combi boiler with a balanced flue approximately 8-10 years old. Its got the lights (which indicate ignite, opeation etc) when you open the bottom panel. I hope that helps.
I have also notice that the pressure relief valve is leaking water from the pipe outside and hence the pressure is dropping to zero which means i need to fill the system - do you think this is the cause - a contributing factor!!
