Hi got a velux roof window GGL c04 and its leaking from the bottom corner into the room, only leaks when the rain is persistent over many hours, went onto the roof to finally try and see the problem and found that 1. The aluminium flashing cover over the wood frame rubber seal appeared damaged, I have ordered a new one £6.00. However the frame at the bottom is split. See photo's any help would be appreciated.
