I was changing the face plate of the light switch to the outside light, it had previously worked fine. When i turned the electrics back on it didn't work.
I used a multimeter to try and find out what was going on, I had 240v between live and neutral, 240v between live and earth, but intstead of having 0 volts between earth and neutral i had about 107 volts. I checked at the light rose to see what reading I had, the upstairs lighting circuit was normal its just the downstairs lighting circuit thats a problem. I have taken out the downstairs lighting circuit fuse and the fuse board and I was affraid it might be dangerous any ideas?
