- Joined
- 26 Dec 2012
- Messages
- 117
- Reaction score
- 8
- Country
I did some work on my heating system today, which is a pressurised system with a Worcester 35CDi II combi boiler.
I drained it, replaced a couple of old radiators and re-filled it. All went well, no leaks on repressurising, but when I fired up the hot water it vented steam and hot water out of the "automatic air vent" on top of the boiler for about a minute, which I assume was clearing air trapped in the heat exchanger?
The venting stopped and the hot water works fine but I'm getting a substantial continuous leak out of the vent now.
There's a small black plastic cap on top of the vent (like a car dust cap) and if i tighten this up the flow stops but I'm worried that this is just closing the vent and that it should be left open?
What I think may have happened is that the venting (which was quite forceful) has pushed a load of crap into the valve which is now stuck open.
Any ideas? Can I just tighten that cap or should I leave it off and get someone out to replace the valve (that job's beyond me, I think!)
