its a lavamat turbo aeg and it hates us! it wouldnt drain so we cleaned the filthy stinky filter, then when we tested it, it now wont fill up. the water pours into the drum and straight through and out into the drain. any ideas??
make sure the drain hose is at raised up above the half way height of the machine and if drain hose is fitted onto a standpipe make sure you havnt pushed the drain hose to the bottom of it as this causes syphoning
