I do hope someone can help me with this issue. I have just discovered rainwater coming up in the sub floor under my floorboards (during a huge downpour of rain last week). It wasn't deep, didn't reach the dpc and subsided as soon as rain stopped, but is still very wet. It just rose through the sub-floor. The reason I found this was I had a leaking fresh water supply pipe, which was replaced and the void had been dried (drying finished on Christmas Eve and floorboards still up so I could see underneath. The drying company are coming back this week to do more tests etc. My bungalow was built in the 1930's on clay soil. There is a soakaway under a concrete drive, which takes rainwater from my roof and from the shared drive with my neighbours. This may even be a shared soakaway as there is a drain and pipe from their roof immediately opposite mine on my neighbour's wall. My neighbour,s bungalow is slightly higher than mine and the drive slopes towards me. My builder says I should have the soakaway tested to see if it's failed (in view of it's age) as it's possible if it's no good the rainwater will rise under the property instead of draining away. I understand the water table is high at present. I dont know who to go to for proper advice; the drainage companies who do free first call outs like Dyno Rod, a building company, a structural engineer, a surveyor have all been suggested to me. I've been researching ACO drains, french drains etc. and am now totally bewildered. Has anyone had first hand experience of anything like this. I have thought of putting different colour dyes down each soakaway and possibly drains (one at a time) to see if any colour shows up next time there is a downpour. The ventilation under the floorboards is good, but there was some mould and damp in the boards following the water leak from the old lead pipe (I don't know how long this was leaking and until I saw the water rise had assumed it was just the leak that had caused the problem and had no idea there was rising water too!) I hope someone can point me in the right direction OTHER than starting to build an ARK!! Many thanks
