Hi
Long explanation but want to try to give all factors to help find solution, have read the sticky on condensation, but want to make sure it is not something else
Story
200 year old cottage, used only for holidays, but have basic heating 1 hour morning , 2 hours at night, while not there to stop freezing and dampness, had roof reslated in July and a breathable membrane fitted(previously no felt), insulated between ceiling and attic floor with rockwool and floored loft, have flame retardant EPS to fit between roof joist but had not got round to doing it was planning on it after christmas holidays, after a 8 day holiday where the house was well heated I noticed all the sarking and all the roof joist were soaking with water dripping from the nail points, is this def condensation or can there be any other problems ?
Facts
Tumble dryer outside house in brick built lean too, so no effect on problem
Bathroom has extractor fan, used always when showering
Do not dry washing on radiators
House probably over heated 18 to 22 degrees (wife feels the cold in Scotland)
Oil fuelled boiler feeding standard water filled radiators in every room
Small multi burning stove in living room, but not used much
Single glazed sash and case windows, problem with condensation on them
Probably don't open windows enough
Think rockwool is pushed too far into eaves,must check
Attic hatch not insulated, ramsey ladder fitted to top of it
Questions
1/ Drying the roof, will a dehumidifier dry it enough or will I also need to heat it ?
2/ How do I insulate the hatch ?
3/ How do I know how much to pull back insulation from eaves?
4/ Will opening the windows regularly solve the problem or do I need to do something else (will also drop the temp to 16 18 max in winter)
Important questions
A/ Do you think the contractor that done the slating on the roof, could have done anything to cause this problem ? I don't think so but want to ask
B/ Anything else I should be doing to help eliminate this problem, suggestions are very welcome?
C/ Should I be doing anything else when I am not there that could relive or help the problem ?
Thanks in advance for any help
Regular reader of the forum, but not enough experience to help with other peoples problem, maybe in the future
Dougie
Story
Facts
Questions
Important questions
Dougie
