Help with 3 way triple dimmer switch please
1 May 2008
Leicestershire
Hi
I have a Marbo Dimmer Triple 2 way mains voltage 250W switch in my lounge.
I bought this as a replacement for previous dimmer, which was broken (although I still have this).
Unfortunately the variable resistor fuses (if this is the correct interpretation) are quite sensitive - a bulb blew &, despite the lower floor fuse tripping, the dimmer no longer works for the affected light unit e.g just stays "full on" if switched on
The replacement dimmer unit is £36.
I've looked at swapping out the offending variable resistor with a good one from old unit - but unfortunately the newer one is not quite the same, and not as easy to remove.
I don't really want to shell out £36 every time a bulb blows to reactivate dimmer functionality !
Can anyone advise ?
Can I purchase just the replacement resistor to swap for blown one ?
Is there a suitable dimmer replacement which has replaceable fuses ?
thanks
Dimmer modules are not variable resistors. They have variable resistors in them, but it won't be that component which has failed, so replacing it would do no good.
Good quality lamps with internal fuses can help, but might not.
Ask the makers about what happens to their dimmer when lamps fail.
