Hello
I have a cooker with a suspected faulty thermometer, which i replaced. However the issue still remains which is that it keeps heating up and not turning off.
When it was first bought the bottom oven wouldn't actually turn on and i was told it was a faulty thermostat which was repaired under warranty.
I'm not sure the controller unit is wired up correctly, but am unable to find a wiring diagram. Does anyone have one of these, or know where the wires should be on the controller unit?
Also the replacement thermostat had 3 connectors on the bottom instead of two, i think its wired up correctly but does anyone know exactly how it should go?
Many thanks
Many thanks
