Help with Accenta G4
29 Jan 2017
Hi guys,
I installed an Accenta G4 with 3 LCD Keypads and an SD2 speech dealer. I have been using the alarm system for 7 years now, but I never managed to fix the following problem:
Whenever there is an alarm, the SD2 dialed calls me. I can press the pin code on my phone and I stop the dialed from calling anyone else, however the siren is still active. Can someone please tell me what I may be doing wrong and how I can fix this? I can send you any photos that you need. I would appreciate any assistance.
Thanks.
The Sd2 has no control over your accenta its just An aftermarket speech dailer ....
Thanks for the fast reply.
1. What can I do to resolve my issue, since the S2 will no do? Is there anything else that I can purchase to stop the siren? The cost is of no issue.
2. If I were to replace the accent a with another device but keep the siren, wired detectors and keypads, is there any better and newer system that you propose?
You need a panel with either text control or ip/app control or just set your bell time to 5mins
Texecom premier 24 , LCD keypad and GSM module + SIM card .....other panels / option available, Galaxy guy does selfmon for Galaxy panels maybe worth a look
