hello all, having a little trouble. i went to look at a job at a farm this week, and the farmer wants some lights in his barn. he doesnt want the whole thing lit up, just certain areas. there is a 3-phase feed to the barn with only a single phase CU with two 16A mcb's fitted. 1 x 16A radial socket circuit in at the moment..
i was thinking of some low energy sodium Flood lights, probably of only 70W each x 12off. and also mabey low energy 7 x 150W sodium lights. with 3-4 light switches.
thats a total output 1890W.
is there anything i should know about sodium lights?
should the lights be wired on seperate circuitts?
what cable should be used within a barn?
would contactors need to be fitted, if so how would one bet fit these?
barn is used for holding cows, though the cows are not bred for milk so the type of lighting is not too important. he wants low energy lighting if possible.
if you have any information i require could you please help.
thanks
thanks
