Hello, I need help in understanding why my bedroom ceiling downlighters are not working. They are on the same circuit as my bathroom and ceiling fan (these are working). I have pulled the can lights out of the ceiling and checked the junction boxes to see that connections are not loose. I have checked the voltage on the junction boxes and all are on 0Volts. The wall switch for the downlighters is a two switch dimmer switch. Although only one of the dimmer switches controls the ceiling lights. I have checked the voltage coming off the dimmer switches and one of the terminals is always 0 volts (see image)
...does this indicate that the switch is faulty or is it because there is nothing coming off of that switch. If its not the switch - then I'm not sure what else could be wrong??
