My toilet has blocked several times in the last few weeks, and each time Ihave had to unblock it using a plunger. Is there a product that I could flush to help prevent this happening again?
Your not looking hard enough mate,it may even be shared and in next doors garden,this was very common in the old days,now we have to put them everywhere
have look next door im sure you will find it if you look hard enough
there could be something stuck in the u bend of the bowl, any air freshners NOT hooked over the side of the bowl anymore??, if not an air freshner it could be a disposable razor or something, might be worth getting the bowl removed to have a nice look into the waste pipe
yea like kirk says t bend blockage. Specialy if the mrs uses moist towel to freshen up. They are a pain in the arse. Even been called out to one outside blockage need to dig up pipe thought it was blocked pair of old knickers. More recently i had one freeze on a 90 bend had a small leak that froze while running and froze up the pipe over time. Got a hair dryer and replaced bend. Seal had perished.
