My downstairs neighbour's kitchen ceiling fell in this morning...
My landlord is away so she contacted a plumber. They found that an open ended copper pipe was leaking heavily behind my cooker. The pipe comes from an old hot water system which was connected to a water tank in the loft/attic of our tenement flat. This system was removed before we moved in and a new boiler installed.
It turns out that the neighbour above us was having issues with her water (we dont know what) ad called a plumber earlier this week.
The plumbers who came into my house said that the plumber called by the upstairs neighbour must have went into the loft and turned on the tap from the water tank connected with our old hot water system, lots of water leaked- he tried to turn it off and the seal is broken so it has continued to leak.
Basically there is an open ended copper pipe behind plasterboard in my kitchen that was leaking.
The plumbers today said that this pipe is very old and there are not fittings available for it anymore. What they have done is used a file on this open ended pipe to make it narrower until they could fit a fitting with a tap onto the pipe.
They said before they left that the pipe was dry, I felt the pipe and said it was wet which they said was water that was already there - despite them drying it already. There is definitely a very small leak (a piece of kitchen roll which I have wrapped around shows a wet patch after 1 minute or so).
I cannot see how you will ever get a water tight seal from a metal fitting onto an uneven metal pipe. All I want to know is- what is the best way to stop it as it is so small- is there a resin/tape that would do for such a small leak or realistically does something better have to be done?
Apologies for the long story for what is a short question- and thanks for your replies.
