Hi All,
I want to install a wireless thermostat to my boiler - A Baxi Combi 105e boiler.
I've added a picture of the current wired thermostat which has 4 wires going into it, Yellow/green, black, brown and blue.
I've done a bit of online research, and it's been quite difficult to find any thermostats that have wires that correlate to these 4 colours. Some are 4 wired but with different coloured wires to those on mine, plus there are some that are 2 wired, some that are 3 wired.
From what I've read, some of these cables are (or can be) redundant, so do I need a 4 wired thermostat for all 4 wires, or could I also open up my options to a 3 or 2 wire model.
So I have 2 questions:
1. Help with the wiring of your suggested thermostat in point 1. - i.e. can I use a 2 or 3 wire product and if so which cables do I use from the picture (and what do i do with the other redundand cables?) - and if I do need to use all 4 cables then what colours on the picture should match up with the colours listed on the newer models.
2. Recommendations for a wireless thermostat between £50-120 with a visually attractive wireless box and decent/easy to use time settings controls - based on the wiring options in point 1!
Any help would be appreciated.
Thanks,
Wialli
Thanks,
Wialli
