HI,
Wondering if anyone can ofer some advice on the following.
I have a 14 month old system which is causing a bit of grief at the moment. it is a sealed system, unvented hot water tank, greenstar 40cdi boiler.
I have three zone valves and radiators are al fitted with TRVs, no room stats and a couple of towel rails, one of which I fitted at the weekend.
The programmer, zone vales and circulating pump all seem to be working fine and boiler fires up, runs up to to the set temperature and then cuts out. Hot water is being fed to the right zones but the return loop is at best lukewarm when the boiler cuts out. As the boiler cools down, the feed loop also cools considerably to almost the same temp as the return loop.
Any ideas what this might be ? Airlock ? something up with the boiler?
Any speedy response greatly appreciated - freezing my **** off here
Cheers
Hoostmun
Cheers
Hoostmun
