Good morning, a little guidance would be appreciated if anyone has the time.
System details ..
-Potterton Netaheat 10-16 boiler
-HW cylinder in the loft
-Pump located in the bathroom, directly above the boiler
-It looks like there is a 2 port valve fitted but its stuck open. If hot water is selected the rads heat up too. As a result my parents have had the rads turned off all summer.
X400 was put in a month ago and the system drained and refilled last weekend. I planned on doing this a couple of times and then putting in some inhibitor.
The rads heat up very well and have all been bled.
The cold feed from the f/e tank doesn't appear to be blocked - if I drain the c/h it fills up again as it should.
My problem is there is no hot water.
Both pipes going into the coil are cold.
Presuming an air locked coil I opened the bleed valve on the upper pipe - only a little air came out and then stopped. No water is coming out of this bleed valve at all.
The 1" pipes going up to the loft seem to be on a circuit including the pump and the 2 port valve branching off this circuit. These 1" pipes are hot about halfway up only.
Does this sound like an air lock in the coil ?
Should I just open one connection where it goes into the hw cylinder ? If so which one, upper or lower, and, should the hw be switched on ?
Alternatively, any other suggestions ?
System details ..
