Hi all
I have just moved into a house and the airing cupboard does not air, I have a spare small rad and the Combi is only above the cupboard so what I was thinking ..
At the mo the baxi boiler has a feed and return for the heating .
If I made the airing cupboard the 1st rad in the heating loop, then after the feed to the airing cupboard fit a two way valve ..
I have the main heating setup on a hive so I then put the main heating hive into and out of the new two way valve so that when I call for main house heating the new two way valve opens , thus also powering the pump in the boiler so the heating fires up and heats the new airing cupboard and the house …
I have a spare hive thermostat which I fit to the boiler and fit this into the airing cupboard set it high so when the cupboard cools down the boiler cuts in and heats only the airing cupboard not the house as the new two way valve will be shut ?
Does this make sense and does any one know if it’s possible if not I’m going to
Have to fit two 2 way valves and a pressure relief valve ..
Thanks I’m advance for any help
Shane
Shane
