When I try to turn my hot water tap off it doesn't 'catch'. If I continue to rotate it towards the off position it continues to turn and the water comes back on again.
I've removed the caps and the hot tap fitting (on left) appears to be sitting proud compared to the cold tap. See the position of the clasp round the neck of the fitting. It is sitting in a notch but on the cold tap the clasp is around the base of the fitting with no sign of the notches.
Can I fix this or do I need a new tap?
If I have to fit a new tap then I cannot see a way of turning the hot water tap off. My neighbours appear to have a little screw on the tap that can be turned to stop the flow of water. I don't have these just straight through pipes to the tap. I suspect I'll need to turn it off at the boiler - is this correct?
Is it safe to do this, fit a new tap then turn the hot water on again?
Thanks.
Thanks.
