Help with fitting door, gap at door stop.
16 Sep 2017
Looking for some advice, fitted a few doors in my time but never had this issue before.
After cutting my door to size and putting it up to see how it fits there is a gap at the door stop (see picture). I dont remember the old door being any thinker than the new. If I move the hinge back this starts to prevent the door form opening properly.
Is my only option to add to the door stop, or start to cut into the skirting to make room for the hinge if I move it closer to the stop?
Any help appreciated, probably an easy question to a joiner but the last doors I have done just went in no problem.
Robert592good evening.
Sorry but cannot see the Image?
Without the Image, most probable other cause of your problem is that the original door was "Bent" or the new one is?? meaning the door was bowed and the original joiner who fitted the door "Bent" the door stop to fit a bent or twisted door??
Ken
What I am trying to is fit a 35mm door into a 45mm frame. The stop can’t be moved.
The door frame is also not square just to make things harder, if a door frame is not square do you cut the door to match or keep the cuts on the door square?
