- Joined
- 30 May 2016
- Messages
- 23
- Reaction score
- 0
- Country
I have a large glass painting (the glass is the medium on which the painting has been done) in a wooden frame, that weighs about 25kg. It has a large wire on the back, so would require two screws/hooks at either side to hang it on.
I'd like to hang it on a wall in my living room. The wall is the external wall of the house, so behind the studded wall, is brick.
What fixings would you guys recommend, that would guarantee the painting isn't going to fall off and shatter!?
I thought I could use something like these heavy duty wall plugs hammered a little way into the brick behind the wall ( http://www.screwfix.com/p/rawlplug-fx-nylon-wall-plugs-5-x-50mm-100-pack/4485g ) but I'm having difficulty finding the correct diameter thread hook screws for them?
The alternative is maybe something like these hook screw anchor bolts ( http://www.ebay.co.uk/itm/M10-Threa...243848?hash=item54310dd888:g:xrwAAOSwvg9XY9Go ) - though I'm not quite sure how anchor bolts work?
Any suggestions?
Any suggestions?
