Please can someone give me a little advice in regards to installing an electric socket in the garden? I want to install a double socket to feed a small water feature and to use for the pump for my daughters bouncy castle. I need advising on the following:
Is it OK to run a cable from a 3-pin plug in my conservatory?
If so what cable do I use?
Does this require a duct or can it be installed directly into the ground?
How low below ground level does the cable have to be?
If any of the above is incorrect then please can someone give further advice.
Thanks.
Thanks.
