Hi i have recently moved into a 1 bed flat, i have spoken to the landlord and his electrician and i am wondering if anyone on here can make sense of what they said cos it seems a bit of an odd electricity set up they have, i am on an E7 tarrif with Eon, the landlord said that only the bottom element in the water tank is linked to this tarif, there is no timer for it either so does this mean if i want cheap hot water im going to have to wake up in the middle on the night to turn it on at the mains switch?? The top element is a booster which is not linked to economy 7. As for the storage heaters, they are on a timer set to come on between 3.30am and 7.30am, the timer is a Grasslin Ecosave (if this helps anyone), these storage heaters are not connected to the economy 7 tariff either (i thought all storage heaters would be?) Does this make sense to anyone? It seems like an odd set up to me and apparantly the electrician said the fuse box does not allow for the storage heaters and both water elements to be connected to E7, any help would be much appreciated, thanks.
