Help with Indesit washing machine
8 Oct 2012
Middlesex
I have a IWME12 modle and the machine has stopped halfway through is cycle with water still in the machine, i can open the door with the water still in the drum which is not good, the power light (red one) flashes as well as two other buttons on the front of the machine :(
Check the filter. Poss blocked.
Bottom right hand corner under the kick strip.
found it, cleaned it up, found loads of coins, just putting the washer through another cycle to test, i will let you know, thanks for your help! :D
