Can someone guide me through the next few steps for this Mira mixer shower. In the picture below I need to take out the `brass section` and then cap the water supply in order to repair it.
I have stripped the above as far back as in the picture below.
Would I be correct in assuming that I will need to remove the tiles either side to get access for removal?
From what I can see there are 3 pipe`joints` as indicated onto this unit, that would be 1 for hot 1 for cold and 1 going to the shower head. Would I undo these three `joints` and then cap all three so that the unit in the picture comes out as a single unit or do I dismantle a bit more before that stage?
thanks
thanks
