- Joined
- 6 Feb 2008
- Messages
- 14
- Reaction score
- 0
- Country
I have an 18 year old barratt house which has some external render at the front. One area which is between the downstairs and upstairs bay window is blown and has been steadily getting worse.
It now needs removing and re-doing. However, I noticed on the inside of the same window (behind a fitted set of drawers, that the internal plaster board is molding and shows signs of damp.
I took the fitted drawers out for a better look and found the board and plaster was moldy. I removed some of the board and it seems the render in the bay window is onto ply board and they have put a damp proof membrane between the ply and the wooden frame. However, they have also nailed through the membrane all over the place!
It looks like water has got behind the render and wet the ply, which is allowing damp in and causing the plasterboard to soak up some moisture.
Is it common to render onto ply like this?
What's the correct way for it to be done and for me to make sure it's rectified so it's fully waterproof?
I intend to remove the render myself and re-board with ply and get a plasterer to then do the render.
