Help with roof felt
3 Jan 2015
Cleveland
Hi guys i have a garage attached to my property with a flat felt roof. I am wanting to install some security strips around the edge. Can anyone suggest best way to fix brackets to the roof without damaging the felt?
Not unless you explain what "around the edge" means no.
Most roof 'edges' have a fascia board to fix to.
What's a security strip?
Hi I am wanting to install some rotating spikes to protect the garage. The brackets use a 4 inch square baseplate to hold the horizontal poles.
We used the same things on the flat roof of a photographers shop around 10yrs ago, we screwed 150mmx50mm pads of wood to the deck then felted over them, then the brackets were fitted to the blocks.
The rain never got in but the burglars still did...they threw a blanket over the spikes :confused:
