- Joined
- 23 Sep 2004
- Messages
- 2
- Reaction score
- 0
- Country
Hi.....as i'm unable to get in my loft i've found someone who could feed a cable to my new CU which in turn will lead to a Garage CU in my shed.
Questions are,
I have been told that rather than run one complete cable to the shed it should be cut and a 30Amp 4 terminal junction box used to re-connect it so that the work can be tested if need be at a later date, regulations i've been told
Originally i was going to use a spur for the power outlet but can now use the CU which will increase the length of the cable from 5m to around 20m, is it still OK to use 2.5mm core cable or should i use 4.0mm.
Does the length of cable used outside need to be armoured, or could i get away with using the heavy duty type as used on building sites, the cable to the shed will not run on the ground but will be up out out of harms way.
Many thanks for your time
Questions are,
