Hey guys
I would like to remove the header tank that is situated above my hot water cylinder in my ground floor flat.
I have connected my taps up to the mains, which are fine obviously. The only thing is, I know that I am not going to be able to hook up my immersion hot water tank up - its only rated for 1.45 bar. Mains is likely to be between 1.5-4 afaik.
Now, this storage tank above MUST go. So I'm thinking either...
A. Making some sort of mini toilet cistern to sit ontop of the cylinder to remove the pressure.
B. Some sort of uprated Steel or Alu cylinder tank?
Can anyone tell me if I am likely to find an uprated tank?
I can take pictures if that helps!
Thanks for any input.[/u]
