Hi, i have justed moved into a new property and the timer for the central heating is not working. The timer is a Switchmaster SM300.
The setup is mains power into the timer L, N and Earth, then one cable to the boiler and one cable to a thermostat in another room.
The timer has power, but the switch does not work and the timer does not rotate. There does not seem to be any power in the thermostat either, but not sure how this works.
On the front plate of the switchmaster there are pins which slot into the mounting plate, but pin number 1 is missing. Has this pin broken or was it not there to start with?
Thanks for any help.
