Hi All. Ive done some research which has confused me more than when I started reading. So thought id post for some advice.
I have a poured concrete screed floor with UFH, its been down 18 months with UFH on low. The surface has been sanded as it had a sheen when it first cured. Im wanting to tile it (have tiled walls before) but wanted to do it right. As such ive purchased the tiles and membrane but have a couple of questions.
1.What adhesive should I be using. Ive looked at Mapei Keraquick Wall & Floor Rapid-Set Flexible and Mapei Rapid-Set Flex Wall & Floor Adhesive. not sure what the difference is other than the price.
3. Ive bought durabase anti-fracture membrane. Can I use the same adhesive as above?
4. My tiles are 150x600mm food effect porcelain. what size trowel notch should I be using?
5. The screed is level, smooth, clean and dry. Ive washed it and vac'd it, do I need to prime it or will I be ok?
Thanks for the advice.
