Before we has a small irrigation sprinkler installed at our home a couple of weeks ago, the only time I could hear any water hammer was if I opened an upper-floor faucet full force and slammed it shut - I would hear one thump that lasted a second in the bathroom itself.
Then we had an in-ground sprinkler installed, and now, if I flush a toilet at night (in a different bathroom off our bedroom), then run a faucet briefly, there is sometimes (but not always) a loud, groaning sound that lasts for about 10 seconds and comes from farther away. Also, two toilets that previously were running fine are now running long after they are flushed.
Our house is on city water with a psi about 78 at the street and a bit lower in the house. The water enters the house through a metre in the basement. The water runs up from the metre to near the basement ceiling and turns 90 degrees to run below the ceiling, all in 3/4" copper pipes. When the plumber attached the sprinkler to the water supply, he made a t-connection a few inches from the initial 90-turn, connecting the T to 1" plex which then runs almost straight 30 feet to an exterior wall, so the plex line is perpendicular but in the same plane as the main line. Outside the exterior wall the pipe runs up to a backflow preventer, then down beneath grade to a master valve.
I have not heard problems when the sprinklers are running but believe the problems are related to the sprinkler installation since they only appeared after the installation.
What might be wrong? How do I diagnose the problem? How can it be fixed?
Thanks for all and any suggestions.
Jon
Jon
