hi all
i already have a switched outside light and want to put up another light but this time triggered by a PIR sensor.
if i run the power from the existing light to the new light with the sensor then i presume i will loose the ability to switch the existing outside light off and on,
Therefore if i want to retain the ability to switch the outside light off and on, do i have to run the new light triggered by the PIR sensor from a separate power supply.
