Hi, I am having some troubles keeping my house and rooms right temp.
I have pre-plumbed cylinder, Mitsubishi ASHP and controller running a two zone underfloor heating setup.
https://heating.mitsubishielectric.co.uk/ForInstallers/Documents/FTC4 Cylinder Install Manual.pdf
I have obtained a copy of the original design from nu-heat and set all the flow rates appropriately now on the manifold. The Mitsubishi controller only seems to want to heat one zone, zone 1 (upstairs) or zone 2 (downstairs) at a time. Every time I check it it seems to spend most of its time heating upstairs and downstairs is not hitting temperature. I leave it on 24x7 and while it is not cold (by my standards, wife disagrees) I think it should be delivering more.
Is there anything else I can do ? Can I get it to spend more time on Zone 2 or even on both ?
The only other things I can seemingly control is a setting I don't understand to do with the zone mode which are Heating Flow Temp, Heating Room temp or Weather compensation.
Every room has an individual stat controlling the actuator on the manifolds which are wired to two UH3 8 zone wiring centres.
