help!
12 May 2008
Sussex
Hello! thinking about get a combination boiler system to combat water pressure problems in my flat. At the moment there is little hot water coming from the tap in the kitchen and the water coming through bath shower mixer tap wont mix and will only run hot or cold!
The water tank is in the bathroom, will the pressure problems be overcome if I get a combi- boiler fitted? also would like to have a decent shower fitted.
Will the pressure problems be overcome if I get a combi- boiler fitted?
Unfortunately not as they require a minimum pressure to work. :(
Think you should get a plumber around to investigate why your pressure is so poor.
Have you tried turning up the stop tap BTW?
If you only have poor pressure on your hot water & your cold water is OK, then this could be due to the height of your storage tank. Best way is to get someone in to give you a quote, he will be able to see it first hand & advise you.
