Hello all, i have got to renew two lengths of copper pipe hot and cold feeds both are linked into HEP20 equal tee's white in colour. Can the existing pipe removed and replaced with a new pipe without destroying the connection and then having to replace both tee's?
Thank you all the tee pictured is the exact one, serves me right for not looking back again at the posts, couldnt get tees off with out key, so cut poly pipes, hot and cold from boiler and elbowed them onto replacement pipes to feed upstairs bathroom. Once new units and sink in place cut polypipe again put in tees for hot and cold to new sink and connected flexi tap connectors via ball valves and some pipe to the tees.
Then proceeded to have a go at the waste "double bowl" and rang the plumber "beyond me"
