Got home last night and i think i must have the worst plumbers in the world fitting my central heating system!!!!
I have a couple of questions if any one would be so kind to give me an answer
1) With the Hep20 system can you join copper to it for visible area's as i have 2 horrendous grey 15mm plastic pipes to my nice new lovley expensive towel rail and to top it they're not even straight, there so tight to the skirting board it looks ****.
2) They've drilled 25mm holes through my laminate floor in one of my bedrooms with the 10mm plastic pipe to the rad that looks really bad (I said they could lift the laminate but they did'nt. Can you buy those collar disc things for the Hep20 10mm pipe that finish the hole in the floor so you can't see the oversized hole.
3) Is it possible to get the installation checked by an independant compay like what building regs do for builders work.
4) Is it o.k to just notch out the top of the floor joist to run the pipes or should they go through centre of joists.
5) Is it also acceptable to use a screw driver to lift floor boards as i pulled back my carpets to see nice split floor boards every where and covered with pry dents from the srew driver. I've taken pictures of all this handy work and some pictures under the floor
6) I recently had my house re-wired and in some places the plumbers have ran the Hep20 pipe directly above the electric wires is this acceptable
