I was planning to use an underfloor heating kit made by hep20 for conservatories. It basically runs as another radiator from what I'm led to believe with its own temperature control valve that sits inside the conservatory.
However, when the house gets up to the right temperture, regardless of whether the temp valve in the conservatory is still below the required temperature or not, the whole system will shut off and therefore stop heating the conservatory too.
Also, I read somewhere (it may have even been on here) that it can take 10 hours for the floor to reach any sort of acceptable temperature - is this right?
Am I better off fitting a normal radiator out there (and still facing the initial problem of the house getting warm before the conservatory and cutting the heating all together) or using an electric wall heater?
Thanks in advance.
Thanks in advance.
