Hello,
A couple of weeks before christmas I had a leak in my house (new build); and after some destruction and investigation identified that the leak was coming from a hep2o T connector supplying cold water to one of my bathrooms (a bathroom which gets very little use). I had very little knowledge of plastic plumbing so a relative (who knows about this stuff) refitted the connector, tested and all seemed to be fine.
5 weeks on and the bloody thing leaked again which I am certain was caused when I flushed the toilet in the bathroom a day or so earlier. This time my dad and I decided to just replace the connector and collars; it was at this time we learned that all you do is pop the collar in the pipe and push-click it into the connector then pull back just to make sure it's gripped in.
One of the pipe ends wasn't quite square, so we squared it up slightly and fitted the new connector. So far, no leaks, but that's not to say it won't leak again in 4 weeks time.
Why would one of these connectors leak, even after refitment? Is it possible that the connector was just duff or is there anything else I should be checking?
Many Thanks,
Nick
Many Thanks,
Nick
