Hepvo trap inline adapter/ bent adapter
4 Mar 2013
Bradford
Hi, I know they do a hepvo trap inline adapter to go to 1.5inch waste pipe, do they also do a bent adapter to go to 1.5 inch waste pipe? Thanks.
What do you mean by 'bent'?
Maybe a standard P trap is what you want?!
Hep Vo's are carp when installed horizontally. Esp on showers where flow rate is low.
If at all possible use it vertically.
Hard won experience
Dreadnought
Never seen an elbow straight off a hep trap, what you could do if you have the space is fit the elbow on to the trap and then fit the straight adaptor into the elbow where the trap would have gone, that gives you inch and a half compression fitting each end.
