Ok. So, I've changed everything that might have been leaking, 3 way, pump and pump valves, pressure release valve.
There are no visible leaks. System losing 1-1.5 bar a day, including today with everything off.
Expansion vessel would cause over-pressure blow-off but not pressure loss when cold.
I wondered if it could be the indirect cylinder coil. My system water is so clear I doubt it would even discolour. Is it sufficient to isolate the cylinder via the return gate valve and the 3 way? Well, I did that and it still went down.
So I switched to HW only ... and it still went down. This suggests the 3 way isn't sufficient to shut off the system.
So now I think I have two options.
1) Install some more gate valves to fully isolate the cylinder coil
2) Install some more gate valves to fully isolate the ground floor rads which wouldn't you ff'ing know it run through concrete with tiled floor over the top
http://www.screwfix.com/p/pegler-ball-valve-red-22mm/45277
I don't see the point in a leak test and repair on the concreted pipes as it'll just go again. Of the options, then though I have no idea where the pipes would go, re-pipe seems to be the only way.
Out of interest, what would a ground floor re-pipe cost for 5 rads?
Any other sugggestions greatfully received but I guess this weekend I'll be draining again and installing 3 or 4 gates.
Cheers
Cheers
