- Joined
- 17 Apr 2007
- Messages
- 2,555
- Reaction score
- 129
- Country
2003 1.9 TDI
Have stripped the rear brakes to sort out a bit of a wine which disappeared every time I pulled the handbrake on.
Turns out a friction lining had come away from the metal plate and all four pads were tight in the carriers. I had a spare pair of pads so fitted them using Ceretec grease and now all is well.
Can the 8mm allen key bolts be replaced with standard hex head bolts?
Simply couldn't get the allen key bolts out. When I so a full disc and pad change, I'll probably need to get the stillson wrench on the job.
