Iv got a hotpoint washer wmfg821 it works fine untill it get to last 1 min then it will just empty then refill and keep doing it till we put it on a different part to stop it any help would be grate
I guess you meant a different programme, the place to start would be to clean out the drain pump housing & filter as it sounds like possibly the tube to the pressure switch may be blocked.
taken the pump off rubber pipe only found a ball in the rubber pipe no filter 20p in rubber pipe wow i am rich pump clean none in front or in pipe work . little 3 hole rubber in outlet pipe one hole had little fluff in it . now all cleaned put back in testing now see if it does same
